make stop for tool change default in material removal simulation
  • February 2, 2021
  • 2138 views
I always want material removal simulation to stop where tool must be changed.  How to make this a default?
Best answer by SteveLucas
If you select stop at tool change from the view menu then do a save of the settings it will save that for the next time you run material removal simulation
thanks much.
