regeneration in creo
I seem to run into a lot more prompts to regenerate in Creo that in Pro. There are some cases when using an old model from Pro in the new Creo manufacturing environment that I can regenerate, hit save, then get prompted to regenerate again. Can't shake the regenerate prompt in these situations. It will always say that the mfg needs to be regenerated if you are trying to save. Anyone have a suggestion for this?
