3-Newcomer
September 26, 2024
split ncl file by time
  • September 26, 2024
  • 2 replies
  • 2030 views
Hi, I need to split a ncl file by machining duration to calibrate the tool before resuming the path.
Federico
Catalina
Community Moderator
September 26, 2024
Hi @NG_1018857,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Moderator
11-Garnet
May 22, 2025
Well.. I do not think this is hard to understand..
I think the interest of PTC in these instances is to try to make sure that if a solution was provided, the original question asker marks the correct solution. This makes it easier for people in the future who might be asking the same or a similar question. They will not have to sift through what could be many posts, but instead will be given the one that is judged to be right. Helpfully, when a response is chosen as the correct one, it is repeated below the original question and marked to show it is the solution.
Hello Federico,
What type of NC Sequence are you trying to split?
Are you using GPOST?
There are a couple columns you can add to the process manager that you might find helpful:
Machining Distance
Machining Time
-Bryant-
3-Newcomer
September 27, 2024
Hi Bryant, we are working a large piece of granite and we have necessity
to split the ncl file every three hours to measure the lenght of the
tool because  milling the granite cause the changement of the tool
lenght. I'm using the volume rough feature.
Best regards,
Federico
PS: i'm the creo's users, Niki Giusti is the ceo of Model Idea
Not exactly the question you asked, but have you considered automatic tool length measurement? This could automate those manual operations. If your control has macros, it is not hard to add a tool probe to your machine. We have used Marposs with good success on Haas controls with no OEM tool setting capability.
