Using sliders with same dimensions automatically
I need 4 sliders for my tool
I select the slider option, put the dimensions and place it at the required/selected point/location. Is it possible to use the same dimensions for the other 3 sliders without the need to manually change the dimensions every time so that i just have to select only the placing location for the rest 3?
