Try the following link: https://alfasoft.science/en/shop/mathematics/mathcad-prime-8-trial/
Hi read the first case and it does not apply to me as it fails obviously to extract the files to the suggested location. I looked in the roaming and local location and there is no Folder from your company.
Tried the second case and turned off windows firewall and virusprotection (as this is the one I have). But the installation fails at the exact same position extracting files 1……100% and then after a small ball circling it just stops at that and no wizard ever starts.
Is there a way to get the msi file from somewhere else and not the pim_installmgr_mathcad.exe that seems tto fail every time.
Dominicus
