Installation error mathcad prime 7. 0 - no logs
  • May 28, 2021
  • 3086 views
I can't to install mathcad. The installer always ask to see file log, but there is not a file log showing a problem. Can someone help me?
Check here, to see if there's a solution to your problem.
Thank you for answer. But I already checked this link before. The problem is that the installation assistant don't show what is failing, it only show a message saying to see the installation log file. So I don't even what is the error in installation. Is there any way to solve it?
No, I didn't find. In this folder there is not anything, except the Diagnostic tools folder(The installation of the Diagnostic tools worked, the problem is only with mathcad prime). I searched this log file in Temp folder, but I only finded an archive in format TMP that I converted to txt, but I don't finded the reason for the failure. I have no idea what to do.
