Installation error mathcad prime 7. 0 - no logs
  • May 28, 2021
  • 3086 views
I can't to install mathcad. The installer always ask to see file log, but there is not a file log showing a problem. Can someone help me?
Check here, to see if there's a solution to your problem.
Thank you for answer. But I already checked this link before. The problem is that the installation assistant don't show what is failing, it only show a message saying to see the installation log file. So I don't even what is the error in installation. Is there any way to solve it?
Did you buy (pay for) a license?: Contact PTC support, get someone on the phone! (Online support should already have come to this forum to provide a solution.)
Are you trying to install Prime 7 Express (no license required)? Check once more that you fulfil all requirements for installation...
