Installation of mathcad 7.0
DP_9497767
I have a problem with installation of mathcad version 7.0. I have installer, recieved it via e-mail. When I try to install it, after runnig installer, there is only extraction of some files, the window disappears and nothing is happening. I tried to download full version of installer from website https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp but there is no file under the name of Mathcad 7.0. I had the same issue with 6.0 version but on that time there was a full version of installer on that site and it helped.
Kind regards
1 ACCEPTED SOLUTION
12 REPLIES 12
DP_9497767
(To:VladimirN)
Thank you for response but it is not working. After runnig the installer and extraction of files, there is no such folder like PTC Download in folder Roaming. C:\Users\YourUsername\AppData\Roaming\PTC Download\MED-XXX-XX-XXX_X-X-X-X\ptcsh0\
It seems as if the installer does not create this path at all.
What Windows OS are you using?
DP_9497767
(To:VladimirN)
Windows 10 Pro
DP_9497767
(To:VladimirN)
Yes, I tried this installer.
DP_9497767
(To:VladimirN)
Do you have any other solution for installation ?
DP_9497767
(To:VladimirN)
In the first link you have to give all the data including email, company etc. I did it and i recieved only this installer that is not working for me.
Unfortunately i had only mathcad 6.0 express so i don't have any product code to give.
DP_9497767
(To:VladimirN)
Thank you so much for all your help ! It helped and everything is working now 🙂
You're welcome.
