Installation of mathcad 7.0
  • January 17, 2022
  • 2 replies
  • 4130 views
I have a problem with installation of mathcad version 7.0. I have installer, recieved it via e-mail. When I try to install it, after runnig installer, there is only extraction of some files, the window disappears and nothing is happening. I tried to download full version of installer from website https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp but there is no file under the name of Mathcad 7.0. I had the same issue with 6.0 version but on that time there was a full version of installer on that site and it helped.
Kind regards
Thank you for response but it is not working. After runnig the installer and extraction of files, there is no such folder like PTC Download in folder Roaming. C:\Users\YourUsername\AppData\Roaming\PTC Download\MED-XXX-XX-XXX_X-X-X-X\ptcsh0\
It seems as if the installer does not create this path at all.
What Windows OS are you using?
In the first link you have to give all the data including email, company etc. I did it and i recieved only this installer that is not working for me.
Unfortunately i had only mathcad 6.0 express so i don't have any product code to give.
You're welcome.
