Same issue - "Errors during conversion xmcd files to Prime": https://community.ptc.com/t5/Mathcad-Installation/Errors-during-conversion-xmcd-files-to-Prime/td-p/758507
Does it convert any file or just the "large number" of files. If it doesn't convert any files then reinstall Prime and the converter. If it is specific files then look at functions in the file that may not be converting.
Hi @JD_14152912,
Did you try reinstalling the Mathcad Prime? What version of the Prime are you using?
Also, if you can repair your .NET framework.
Dhiraj
