Issue converting Mathcad 15 to Prime
  • September 18, 2025
  • 3 replies
  • 262 views
I am looking at converting a large number of legacy mathcad files to mcdx files. When I try to run the converter, it fails pretty much immediately, with an error: System.Runtime.InteropServices.COMException (0x80040CB6): Unknown Error at mcautomation.IMathcadWorksheets.Open(String pFileName) at ConverterLoader.Xmc...
Please can you advise what the issue might be here?
James
Best answer by VladimirN
Same issue - "Errors during conversion xmcd files to Prime": https://community.ptc.com/t5/Mathcad-Installation/Errors-during-conversion-xmcd-files-to-Prime/td-p/758507
18-Opal
September 18, 2025
Does it convert any file or just the "large number" of files.  If it doesn't convert any files then reinstall Prime and the converter. If it is specific files then look at functions in the file that may not be converting.
VladimirN24-Ruby IIIAnswer
Hi @JD_14152912,
Did you try reinstalling the Mathcad Prime? What version of the Prime are you using?
Also, if you can repair your .NET framework.
Dhiraj
