7-Bedrock
March 1, 2026
License contains error
  • March 1, 2026
  • 79 views
After Install. I obtained License file online.
Install the license, it shows i am all setup ready to run.
Mathcad Version 14 M020
When i run Mathcad, the says the license i have requested contains an error
Invalid Host.
It returns PTC_HostID=1870:7F0D i ENTERED A "-" NOT an ":" (i ENTERED 1870-7F0D)
FlexLicensing error 9.57
Best answer by ptc-2010295
thank you for your reply.
As it turns out, The solution to my problem was:
to configure the MCLicense.exe  to run in compatibility Mode "Visa SP3"
This fixed the problem.
My version / License request the "vol C:"  serial # and does not use the network card.
I had updated my SSD, and this caused Mathcad to stop working.
I am running windows 10, and I guess Version  14 M020 runs best in Vista mode.
"Error (-9,57)", quote: "The error β€œThe License file you have requested contains an error, Invalid Host. The host id of this system does not match the host id specified in license file. FLEXnet Licensing Error: -9,57" is received while launching FLEXnet enabled applications like Creo.
The common solutions for this are listed here in the most frequent order": https://www.ptc.com/en/support/creo-admin-troubleshooter/error-code/other-errors/error-9,57
ptc-20102957-BedrockAuthorAnswer
7-Bedrock
March 2, 2026
