Mathcad won't download
  • January 30, 2021
  • 1427 views
There is no option to download Mathcad once I reach the "application selection" section of the installation software, it just shows a blank prompt. what do I do to fix this?
@unknown,
Could you try below steps?
  1. Click on Back button once
  2. It will take back to earlier step
  3. Again click Next and wait for a moment till the list appears
  4. If list is still not displayed try above steps again till the list appears
it doesn't work
@김일_9733165,
How many times you repeated above suggested steps?
Also, check whether .NET Framework 4.5.1 and Microsoft Visual C++ 2008, 2010, 2012, 2013 and 2015-2019 SP1 Redistributable Packages (32 bit as well as 64 bit) are correctly installed on your machine.
