Is there a way to set the Mathcad language? I'm German and have a German Windows system and would like to use Mathcad in English with English spelling checks. Is that possible?
Some old discussion - "How do I change the language in mathcad Prime 3.1? Should I reinstall it?": https://community.ptc.com/t5/Mathcad/How-do-I-change-the-language-in-mathcad-Prime-3-1-Should-I/td-p/179934
Hi Vladimir,
so some answer you got seven years ago: It works, thank you for your help.
You're welcome.
