A calculation of steam fluid flow pressure loss
- April 24, 2013
- 3 replies
- 10419 views
Attached is a steam flow pressure loss calculation.
I broke it down into three file. Please make sure your mathcad has internet access because
Thermodynamic Properties of steam flow is based on IAPWS-97 mathcad server . I really appreciate the authors effort
You probably has to rework the file reference in the "steam head loss PartIII " to point to the other file
the reference of viscousity calculation can be found in the mathcad file
The fanning friction factor is simply a find(f) of the colebrook-white equation thanks to the power of mathcad, dont we all love that?.
I would like the community effort to check the validity of the calculation (I only check a few result and it seems to be matching table/graph value of steam pressure loss)
You can go to "steam head loss Part III" to change the pressure, temperature and piping data. Feedbacks are most welcomed!
The file only works in (and hopefully it works):
0<T<800C, P<100MPa and 800<T<2000C, P<50MPa because that's the range of IAPWS-97
BTW, I am struggling with my career and if anyone is interested in hearing me whining please send me a private message.
