[API: VBA] How do I get the output from Mathcad worksheet?
Hi All,
I would like to obtain a value of a variable from my worksheet. Let say my worksheet has x:=1 and y:=x+1=2. What function can I use to get the y value? I was trying with Worksheet.OutputGetRealValue(&As)("y") but I got an error instead. The following is my code:
Sub test01()
Dim WS As Ptc_MathcadPrime_Automation.Worksheet
Dim App As Ptc_MathcadPrime_Automation.Application
Set App = New Ptc_MathcadPrime_Automation.Application
FileName = Application.GetOpenFilename(MultiSelect:=False)
Dim conNum As Integer
i = 22
conNum = Cells(i, 7)
Do While Cells(i, 1).Value <> ""
'' inputs
Set WS = App.Open(FileName)
Call WS.SetRealValue("#", Cells(i, 7), "")
Call WS.SetStringValue("M1", Cells(i, 2))
'Call WS.SetStringValue("M2", Cells(i, 4))
Call WS.SetStringValue("M3", Cells(i, 3))
Call WS.SetStringValue("M4", Cells(i, 1))
Call WS.SetRealValue("D2", 3, "")
Call WS.SetRealValue("D3", 3, "")
Call WS.SetRealValue("D4", 3, "")
Call WS.SetRealValue("D1", 3, "")
Call WS.SetRealValue("P1", Cells(i, 5), "kip")
'Call WS.SetRealValue("P2", 10, "kip")
Call WS.SetRealValue("P1", Cells(i, 6), "kip")
Call WS.SetRealValue("T1", Cells(i, 8), "in") '' need to be added
'' check all checks
WS.ResumeCalculation
If WS.OutputGetStringValue("check1") <> "OK" Then
Debug.Print ("check1:= not ok")
End If
Do While WS.OutputGetStringValue("check2") <> "OK"
N = WS.OutputGetRealValue("D2")
D2 = CDbl(WS.OutputGetRealValue("D2"))
Call WS.SetRealValue("D2", D2 + 1, "")
I would like to manipulate D2 value, how do I do that?
Also, is it correct how I use OutputGetStringValue function? the "check2" in my worksheet is "check2="OK""
Thank you very much!!
