Array Units & Value Decimal Places
- September 14, 2017
- 5 replies
- 4893 views
Referring to the report extract I have attached, I have an array that captures reserve factors of a structrual analysis. It also captures the input data into those reserve factors.
I have two issues with the display of this data.
1) I cannot customise the units, i.e. I would rather some of the psi units be displayed as psf however it appears that mathcad does not allow the use of custom units in arrays? Further to this, when I backspace on a unti, it deletes the whole array rather than just the unit I want to delete and replace.
2) The RF column needs to be displayed as 2 decimal places but not the allowable or applied columns, these need no decimal places however, when I select the value or the column I need to change and then change the number of decimal places to be displayed, it changes all values in the array not just the column or value I have selected within the array?
Note that both of these techniques work with the individual values outside the array.
To me, these both seem fairly obvious things that should work within the array the same way as they work outside the array.
