Assigning a variable to a result of a "series" symbolic operation
  • October 28, 2020
  • 1765 views
I want to put the result in a variable f.1(x), but the mathcad says that this variable is undefined. The only way that works is to assign by-hand (as seen below) but i would like to know about more clever solution
What you did should work and it actually does:
But without seeing your sheet its quite difficult to guess what could be wrong.
P.S.: I noticed the the result of the symbolic evaluation looks different in your pic (while being mathematically the same). Especially the factor 1 are somewhat irritating as Mathcad usually doesn't do this - even if you don't tell it to simplify.
Which version and maintenance release of Mathcad are you using?
MC15(M050) sheet attached
Looks like a Maple result. I guess Mathcad 11, 12 or 13:
Ah, quite possible.
But nonetheless the assignment should work OK, shouldn't it?
