Automatic update/ regeneration (twice) of a creo model including a mathcad prime external analysis
  • June 21, 2017
  • 0 replies
  • 879 views
I have created a Creo model using a Mathcad Prime external analysis that calculates a parametric Bezier-curve based upon Creo parameters. I am using the Bezier-curve to create specific geometry inside my model.
The trouble I am having is that I always need to update/ regenerate my model twice for the geometry to change based upon the Creo parameters changing - the first regeneration updates the Mathcad analysis, the second one updates the geometry.
Is there a way to force Creo to update/ regenerate the model until no further changes (neither Mathcad results nor subsequent geometry) occur.
Thanks for any hint you might have to alleviate this issue.
Kind regards,
Carsten
