Can someone help with the Find(x) function?
  • November 11, 2016
  • 2325 views
I have attached a pdf file with an explanation of what I am trying to accomplish.  The Mathcad file attached can be edited as needed.
Hi Derek!
I give you some advice:
dhanson-21-VisitorAuthor
F.M.
In the attached file I have prepared a revised format as you described.  However I am still not getting the values I would expect based on the individual calculations.  Can you look at the attached file and answer the highlighted question at the end of the first page?
Derek
But in the original file, you gave L = 0.3gal!?!? Now thou hast changed to L = 78in?!?!
So what is the unit of L? However, L is not used in the entire worksheet.
Here below is a photo of the original file with the changes I had made.
This is my opinion. I would like to know also the one of other people from the community. Let's wait for a while.
