Converting backwards MCDX to MCD
is it possible to convert MCDX-files backwards to MCD-files?
Best regards
Michael
Best regards
Michael
As explained there is no tool to do the job.
By hand means:
- You open the Prime sheet, to be able to view it.
- You open the (real) Mathcad application (some version of 1 through 15, your choice) and start creating a new (.mcd or .xmcd) sheet.
- Now you create representatives of each region of the Prime sheet in the new (real) Mathcad sheet.
- And finally you save the (real) Mathcad sheet.
As a sort of check, you could convert the new (real) Mathcad sheet to Prime and compare the results, to see if you missed anything.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
