Creating the “enveloping” ellipse for a Monte Carlo plot?
  • September 20, 2018
  • 2 replies
  • 6108 views
To all
 I am doing my 1st step with the montecarlo() function in mcad 15. I copied the example and put my own function and it seems to work fine.
Does anyone know if there is a way of getting/creating the “enveloping” ellipse one often sees on a Monte Carlo plot? I attached one on which I drew the ellipse
I think the length of the minor and major axis have a meaning (in the Mont Carlo world) byut can’t quite remember what it is!
Best answer by JBlackhole
Get the mean data X0 =(x0,y0)
Get pts
1: X1=(x1,y1) x1=min(x), y(x1)
2: X2=(x2,y2) x2=max(x), y(x2)
Centre of the ellipse is X0
Major axis a =|| X2-X1||
Rotation angle of the ellipse atan(|X2|/|X1|)
Search minor axis (b) to envelope all the pts
Plot ellipse translated by X0 and rotated by alpha
JBlackhole16-PearlAuthorAnswer
Get pts
23-Emerald I
September 25, 2018
And the minor axis is?
23-Emerald I
September 25, 2018
How about this?
You've calculated the angle for the major axis.  (I liked what you've got so far.
Now
    Rotate all of the data so that the major axis is parallel to the x axis.
    Then the length of the minor axis is max(y)-min(y).  And the minor axis is normal to the major axis, so you know the whole ellipse.
Here's a solution that uses Minimize to make an ellipse of minimum area that includes all the points.  Seems to work.
4.0/pdf attached
Thanks for that.
Thanks to Fred and yourself for the input. Really appreciated
