Cumulative addition from different arrays
Hi guys, can someone assist me with this one please? Seems like it should be fairly straightforward but it's got me stumped! A bit long-winded to explain so bare with me.
I have data representing mass of concentric steel pipes and mass of the cement in the annuli of the pipes, bonding the pipes together, in separate arrays. The pipes/cement are long and get cut into manageable lengths. The columns in each array represent the remaining mass after each cut. The rows in each array represent each pipe or cement 'donut'. Hopefully this diagram helps, which is a cross-section through the pipes/cement, looking at one half only. The black bits are the pipes (3x), the orange is the cemented annuli (2x) and the red represents the interfaces between each pipe and the cement - 'cement bonds', of which there are 4:
This is the array for the pipes (3 pipes, 6 cuts):
This is the array for the cement (2 cemented annuli, 6 cuts):
I have an array for the number of cement bonds:
And an array for the number of cuts:
The outer pipe (pipe 0) is held. What I'm trying to achieve is a single array with number of rows matching the number of cement bonds, each row representing the total mass that each cement bond is having to hold (if we assume there's no slip between steel/cement), working inwards. The number of cuts (columns) will be the same as for the pipes/cement. So, for example:
cb0 will be the mass of cement0 + pipe1 + cement1 + pipe2
cb1 will be the mass of pipe1 + cement1 + pipe2
cb3 will be pipe2 only
There could be any number of pipes, the number of annuli will always be one less than the number of pipes (centre annuli will never be cemented), the number of cuts varies but is driven from array cr. The pipe ODs are given as an input, so this can be used to determine number of annuli/cement bonds:
I've managed to calculate the first and last cement bonds using if and else if functions (might be a better way though), it's the ones in-between that need cumulative addition from separate arrays I'm really struggling with! Any help would be really appreciated.
