Custom units in Mathcad Prime 6.0
  • September 14, 2020
  • 2462 views
Hi folks,
I'm trying to define custom units in Mathcad Prime 6.0, but for some reason I don't seem to be able to. I define the unit as a variable and then try to change the label to "Unit", but Mathcad doesn't keep the change.
I used to do this in previous versions within a nanosecond, now it doesn't seem to be working, so I'm wondering if this is a bug in the software or I'm missing something...
Anyway, just putting it out there to see if anyone has faced this issue with Prime 6.0.
Thank you!
J.
Please post the worksheet...
nitrox71-VisitorAuthor
Hi there,
Here's a file with a few examples. I cannot get the label to change from "variable" to "unit" no matter how hard I try.
Let me know your thoughts.
Thank you!
Not clear what exactly you tried.
You have to label the new unit as unit when you define it, nor only when you use it.
I attach the file with the "variables" changed correctly to units.
