Cycle through worksheets with Readfile
  • September 17, 2010
  • 3 replies
  • 19031 views
Hello folks,
I have about 80 Excel files with each containing 24 worksheets full of data. I'd like to cycle through each Excel file's worksheets to read out the data in a loop using Readfile. For obvious reasons doing this via the import wizard is too cumbersome.
Readfile however does not offer to choose a certain worksheet within an Excel file. Has anybody an idea how to overcome this shortcoming?
Thanks in advance
Raiko
Raiko Milanovic wrote:
Hello folks,
Thanks in advance
Raiko
Raiko,
Can you post an example, think I've got something that will work.
Mike
Please see attached worksheet.
Tom Gutman posted the sheet a while back which writes data to multiple worksheets within a Excel file. I am hoping Tom or another collab can modify the script in the textbox so data can be read from mulitple sheets instead of writing.
Mike
Another example.
I have used an Embedded Excel component and specified each of the sheets when defining the data range. One problem is that M14 is only compatible with Excel 2003 - Will this be a problem?
Mike
Fred,
That is a fantastic piece of work, well done.
Raiko,
Have a look at the attached worksheet – It reads data three different worksheets within one Excel file. For your example you could write a function to loop through each of your sheets.
I have also attached an image to prove its working on my machine
Mike
Raiko17-PeridotAuthor
Fred, Mike,
many thanks for your effort.
I still have a problem with the scripted object, as the debugger maintains that it doesn't know/support the the GetObject method.
Any suggestions?
Raiko
the scripted object is wreaking havoc on my machine (Win XP SP3 with Office 2003 and MathCad 14 version M030) so I won't go further into this and go for an upgrade to MC 15 soon.
Thank you very much for all the work you put into this
Raiko
Raiko,
That is such a shame, the function has been developed within this thread and the only person unable to use it is you and it was your request.
I would still like to help if possible.
Have you managed to call in data from the first sheet within Excel?
Mike
