I'm using PTC Mathcad Express Prime 3.1 for my UNI work.
Unfortunately, I hate using Tahoma as my default text font. Is there a way to permanently change the default text and math fonts to something like Cambria Math?
It couldn't be easier, although it is not intuitive - since I also struggled to figure it out. Simply click on a blank part of your file and select your desired font (including size) under BOTH the Text Formatting and Math Formatting tabs. That sets your defaults for that file. Any text or equation you make from then on will your new selection. Save your file as a template and your preferences will be waiting for you whenever you open it.
