Define discrete function
  • January 11, 2013
  • 3 replies
  • 5515 views
Dear MathCAD-Experts,
I've a for sure very simple question: How to define a discrete function? Please see the picture attached. I want to define the function c_W(phi_Wind) with discrete values. So for example c_W(30°) should be equal to 8.2 m/s.
Thank you very much for your help,
Muh
Best answer by RichardJ
I should have said "lookup", not "vlookup".
Attach please the Mathcad Prime file!
See cspline and others some functions.
Please see attached
When you lookup the angle, what are you expecting as a return value?
See the vlookup function in the help.
With vlookup I can only search things in a vektor but I want to define a solution vector of a function!?
RichardJ19-TanzaniteAnswer
I would recommend writing a program with statement to select the correct values for each angle. You even add in a feature if 25 degree use 30 degree values. Hope this helps
I tried this in every imaginable way, but it seems that MathCAD does not allow that...
