Defining a Curve
  • September 1, 2017
  • 9920 views
Hello to all,
I am interested to know if it is possible to mathmatically define a curve as a function. i.e. if I have an xy plot which I have created a curve for i.e. a polyfit or similar. Is it then possible to get MathCAD to define that plot as a function of x? i.e. if I have a polyfit line (which I understand to essentialy be an extrapolation of the xy plots themselves) can this polyfit line be defined as a function i.e. y(x)?
Andy
Best answer by Werner_E
Here is a sheet in Prime 3.0 format.
Hope it helps.
To use the function without the data availabe you would copy simply the "coeffs" vector (set Prime to show more decimals for better precision) and assign it a variable "coeffs" which you then can use for the function definition as shown.
The regress function returns coefficients of the polinomal for the approximation!
awibroe1-VisitorAuthor
Any advice on how that works?
Thanks everyone I think I have what I was after now! Thanks for taking the time!.
