8-Gravel
April 5, 2023
Extracting data from Excel Table
- April 5, 2023
- 1 reply
- 2456 views
Hello All,
I'm trying to convert excel sheet formula into Mathcad.
Example, I want to extract P/N No. from the excel table.
Stud dia and Load is the input variables.
- Nominal Size is the stud dia.
- Once stud dia is entered remaining rows with different nominal size is ruled out.
- Then compare input load value against excel sheet min and max load.
Load value should be more than the Min load value and near to maximum load in case of multiple variables.
If load value is not available in the Column 2 and 3 then same steps will be carried for parallel min and max load (column 4 & 5).
- Same concept was followed in excel sheet calculation. Now I need help in making calculation in Mathcad file.
Can you please help me on this problem.
