File type is not supported
DominikT
Hi all,
I need your help. I saved my mathcad file and then my computer crashed and now i cannot open it. It says 'The file type is not supported. Log file is located at C:\ProgramData\PTC\Mathcad Prime\Logs\MathcadPrime-Exception_20200506_163436.log Can i recovere it? This is very important! I use Mathcad Prime 5.0
6 REPLIES 6
@Dominik, Check the size of the worksheet by going to properties (Right Click > Properties). If the file size is in few kb it means nothing has been saved in the worksheet.
For further confirmation create a case with Technical Support with attached worksheet. Technical Support will try to recover the worksheet if possible.
DominikT
(To:Sanath)
Thank you I will ask them. And the size of the worksheet is 6,02 MB.
ovi97
2-Explorer
(To:Sanath)
Can someone please help me convert these files, from XMCD to MCDX?
VladimirN
(To:ovi97)
Please find it in attachment (for Mathcad Prime 3.1 and versions older).
(To:VladimirN)
Older? Rather for newer versions, right? 🤔
I have the same problem. Can you help me please. It is very important
