File type is not supported
  • May 6, 2020
  • 3599 views
Hi all,
I need your help. I saved my mathcad file and then my computer crashed and now i cannot open it. It says 'The file type is not supported. Log file is located at C:\ProgramData\PTC\Mathcad Prime\Logs\MathcadPrime-Exception_20200506_163436.log Can i recovere it? This is very important! I use Mathcad Prime 5.0
@Dominik, Check the size of the worksheet by going to properties (Right Click > Properties). If the file size is in few kb it means nothing has been saved in the worksheet.
For further confirmation create a case with Technical Support with attached worksheet. Technical Support will try to recover the worksheet if possible.
