Gaussian peak with a left tail
  • March 10, 2011
  • 2 replies
  • 6176 views
Ok, here one more problem
I imported some data and i want to fit a gaussian peak
That is not a problem. I used genfit with a gaussian distribution function and everything is fine.
But in some peaks I have left and in some others, right tails. I tried many ways by adding to the gaussian function others,
but the results are not good enough. Are ther any sugestions?
Also I would like to ask if it possible to add more fit functions, in Mathcad Prime.
Sometimes genfit take a lot of time to fix it, when the data are not complicated enough.
Thank you for your time.
Could you post a worksheet with the problem data and the fit that is not good enough..
Please do not pay attention on the second peak that is on the left of the big one.
If there is something you can't understand please let me explain.
Might be simpler to use Given ... Minerr. See attached.
Alan
I think the result depends strongly on guess values.
