Hello All,
I was wondering if any of you had a chance today if you could take a look at this Mathcad file. I have highlighted the area where my given/find code breaks and I am not sure what is the issue.
Thank you very much.
Sometimes using T1 with a subscript and sometimes without a subscript.
Have changed some of the file to get the solve block to work but left some of the file with errors to show you.
Cheers Terry
Cheers Terry
You need define this.
Left side of := must without * .
