Graph in Mathcad
  • July 1, 2011
  • 2 replies
  • 5836 views
Find the attached image. How to plot such a graph in Mathcad 15?
Dhinesh
Best answer by MikeArmstrong
Please see attached. I have used the Lines function to create the vertical lines on the X-axis, but had to use vector's to create the lines on the Y-axis. It works, but looks untidy. I'll have a go at writing a function for the Y-axis now.
Mike
Can you provide a worksheet with the data?
I'm sure the graph can be done, but too lazy to type the data out
Mike
dm-31-VisitorAuthor
Mike,
pfa
I know the graph can be plotted.
But I need similar kind of output as in image.
Dhinesh
Mike
Hello!
The easiest and fastest way is as follows:
dm-31-VisitorAuthor
Vladimir,
Which graph option I have to use? What are the settings I have to do?
Dhinesh
The settings for plot can be changed using tab "Formatting" (right click on the plot and choose in the list "Format .."). Basic tab with which it is necessary to work it- "XY Axes", "Traces", "Labels".
P.S. I have attached to the message file for Mathcad 15.
