Help with plotting function
  • June 28, 2021
  • 2 replies
  • 1454 views
New to Mathcad. I am stuck at this for last 3 hours. I have a V as function of x, i defined x as an array now I want to plot V(x) on y axis vs x on x axis. It shows me errors like function is not defined and value must be function. Please see and help
ttokoro
May be you need * .
t.t.
In case you overlooked the difference in ttokoros answer - you missed to type a multiplication sign between "w" and the opening parenthesis. Omitting this multiplication and simply typing "w(..." means that you a referring to a function w, which of course is not defined. Hence the error message.
Prime offers a rudimentary error trace facility.
If you type V(3ft)= you get the error saying that it must be a function:
If you now switch to the calculation ribbon and use the error trace facility, you are pointed to the place where the error really occurs:
Unfortunately this does not work from the error you got when you tried plotting V.
