How can I implement this on MathCad?
  • February 6, 2026
  • 334 views
Hi, it was requested on my company to focus on Mathcad for calculation of new designs.
It is a great tool, but how can I replace Excel in a inductor design like the image attached?
Where I need/can see the different designs all together to evaluate them.
Here we use Mathcad Prime 10.0.1.0.
Thank you for the support.
Best answer by terryhendicott
Here is version 10
Use an input table to enter inputs,
Use a matrix to show inputs and calculated values.
Like this.  You actually  get the units in Mathcad.  The columns of the input table are variable names for a column vector of values.
To display it identical to the spreadsheet.
Create a matrix by augmenting all the column vectors, Then transpose the matrix
If the spreadsheet is not propriety can you upload it so this can be shown?
Cheers
Terry
Thank you Terry!
Which version of Mathcad you used to save the file?
Asking because I could not open on 10.
Here is version 10
