How to find Maximum Value of Sine function over a range of time.
  • January 20, 2012
  • 3 replies
  • 11574 views
I have a function like this:
The Plot of this function looks like this:
I want to find the maximum value of this function within time range of t= 0 sec to 0.1 sec. If I put initial guess of 0.03 s the maximize function gives the maximum value within the cycle at 0.03s. How do I find maximum of different cycles within a range. Any help is appreciated very much. I have attached my work sheet here.
mesipa1-VisitorAuthor
Thank you very much for your valuable response
23-Emerald I
January 20, 2012
Once again, brute force!
I Thank you very very much, This one is much more shorter than previous. Appreciate it.
Fred's is nice, I agree.
But it's not actually shorter. You must manually step to find the peaks, or you might miss one. Also, If you want the max absolute value, then you must add to the program and have even more steps.
If all you want is the maximum positive value, then creating a vector of values,v and using the max(v) is as short as you get and does not require any manual intervention.
But, depends how much information and how automated you want.
I spent a little more time and extended to find all of the roots and the local extrema between the roots, and the locations. But once the functions have been defined, only have two functions, one for zeros and one for local extrema.
Here is a worksheet which has been passed in the forum several times.
Mike
Thanks Mike.
