Is there a way to plot a function of (x,y) like ezplot in Matlab?
  • March 3, 2017
  • 3 replies
  • 8046 views
Hi, guys
I want to plot the function:
f(x,y) = x^2 + y^2 +x*y - 3600, bounded with f(x,y) <=0;
Just like the graph shown below:
The figure is plotted with ezplot in Matlab.
function a=elp1(x,y)
     a=x.^2+y.^2-60^2-x.*y;
end
figure(1)
h1=ezplot('elp1',[-90,90,-90,90]);
So far I haven't figured out an alternative in Mathcad that can do this.
Could you help me with some ideas?
Thank you very much!
Best
Shawn
Best answer by ValeryOchkov
One general method for any f(x, y)
Hi Shawn Fan,
your function is a quadric which can be plotted as follows:
the 2D plot looks like the intersection of the quadric with a plane parallel to the xy plane (z=f(x,y)=a).
For me this is the most simple and basic method ...
Best Regards
FM
Lace
sfan1-VisitorAuthor
Thank you!
Unfortunately I am using Mathcad Prime now and it appears that Prime cancels the infix operator (so sad)
I would use the convergence of say f(x,y) <= 0 to generate a solid(with many points) circle then.
So sad Prime cancels this useful function that looks like a devolve.
Considering Matlab recommends fplot over the old ezplot, while fplot does not come with the same function as ezplot, I feel a little bit better, LOL...
Still, thank you Valery, thank you FM!
An ingenious method implemented by Viacheslav  N. Mezentsev to do implicit 2D and 3D plots (even for Prime) can be found here:
Re: implicitplot2d()
sfan1-VisitorAuthor
Thank you so much Werner!
This function is very quick!
I will refer to Mezentsev in my homework.
Thank you!
Another method from Viacheslav A.Tarasov. It works in MC 15 but does not work in the Prime (why?).
Viktor
