Issues solving a second order ODE
  • December 7, 2018
  • 2 replies
  • 3546 views
Hi folks,
I am trying to solve a second order differential equation in Mathcad 15 to model the diffusion of a substrate in a spherical pellet. Regrettably, Odesolve gives me the following message: 'This function cannot be used here' (see attached file). I have tried to rearrange the equation in different forms to see if that helped, but I still have the same problem. Do you know how can I solve the issue?
Best,
Daniela
Best answer by dramosblanco
This indeed solves the issue. Thanks Alvaro!
Best,
Daniela
Did you set up the Odesolve block correctly? For example:
- Wrote the derivatives using the proper symbols and operators?
- Is the highest derivative linear (not multiplied with t or the solution function y(t))?
- Did you provide sufficient/enough initial conditions?
Thanks for your answer. Regarding your points:
- I used prime notation for the ODE and boundary conditions in addition to using the boolean equal. I think there should be no problems with this point.
- Yes, the highest derivative is linear
- Yes, it's a second order ODE and I specified 2 boundary conditions.
I attached the file in case you want to have a look at it 🙂
Best,
Dan
23-Emerald I
December 7, 2018
No file attached!
Hi. You have 2/r*cs'(r) as part of the differential equation, and set c(0)=0. (The other condiont isn't initial, it's boundary, and have not problems) Mathcad can't handle r=0 here. Or change to c(0.000001)=0 or change the numerator where r appears as r+0.0000001.
Best regards.
Alvaro.
dramosblanco1-VisitorAuthorAnswer
Best,
Daniela
