Jacobian matrix
  • March 10, 2022
  • 2 replies
  • 7959 views
Hi community
in this simple example,is shown how Mathcad help me to find a singularity value (det J = 0)
 thanks
Is there any question you have???
Why do add and not subtract. Furthermore it looks like you ran into Prime infamous auto-label trap and will have to manually label all variables the same.
Is there any reason you are not using the built-in "Jacob" function?
Would be straightforeward - here done in MC15
XDN14-AlexandriteAuthor
Hi Werner
I use Prime , because finally i connect calculation sheet with PTC Creo 3D CAD
In my example, i know the det(J)=0 with only q2=0 or q2=180 ( l1=squareroot 2 l2=1) : this corresponds to the alignment of the robot leg (l1 and l2)
but i can't find it with mathcad
in don't know "Prime infamous auto-label"
First of all you have to correct you error and change the plus sign to a minus to calculate the determinant the correct way.
You may also use the matrix determinant operator |J| or ||J|| to do the job.
If you still do not get the simplified result shown in my previous answer you have to look at the labels of all of your variables theta1 and theta2 and change them manually so all are the same - either all "variable" or all "-" (which means "automatic"). The symbolic engine does not like variables which are labeled differently and treats them as different variable which seems to be the reason why in your pic theta2-theta2 is not simplified to zero, etc.
As already written above using the "Jacob" function (and the determinant operator) would be the most natural way but as I have notice it seems to be broken in the new symbolic engine. So if you are using Prime 7 you have no option to switch back to the legacy symbolic engine and if the bug is not already fixed in P7 you can't use the "Jacob" function.
BTW, in future threads I would advice that you clearly state the problem you experience and the question you have and that you also always attach your worksheet as well.
OK, I further looked at the problems with Prime and I still consider it a bug in the new symbolics but there is an easy workaround.
The reason for the bug seems to be that the new symbolic engine is not always able to determine correctly the number of arguments in use. So the workaround is to just use the optional third argument of the "Jacob" function and tell Prime the number of independent variables in use.
There is a further problem in Prime when we try to solve for theta2. Primes new symbolic seems to not like vector indexed variables to solve for. Substituting the vector element for a "normal" variable seems to cure this problem.
Prime6 worksheet attached
PTC support says:
I reported the issue to R&D
Details in CS364786
wait and see
Thanks Werner
Waiting (for at earliest Prime 9, I guess) doesn't hurt that much as there is an easy workaround.
