8-Gravel
July 18, 2022
Loop program
  • July 18, 2022
  • 2 replies
  • 3253 views
The problem is the R loop solve 2 instead of 1 and the Vx loop solve 2 instead of 3. What’s the problem?
18-Opal
July 18, 2022
Don't know why the units cause problems.
See if this helps https://community.ptc.com/t5/Mathcad/Using-Units-in-a-for-loop/m-p/84351
When you learn programming than one of the first things you learn is that you should never compare float values for equality but rather ask if the absolut value of their difference is smaller than a certain small value like 10^-10.
The use of the units results in very small floating point rounding/conversion errors and so (l-b) is not exactly equal to x.
You may do it that way:
Or define a function
BTW, your programs don't contain any loops (no "if" and no "while").
8-Gravel
July 19, 2022
Thank you for your input. Is it possible to use different calculation formulae depending on x value
              If x = (l-b); Matcad use formulae 1 to solve R
              If 0 ≤ x < (l-b); Matcad use formulae 2 to solve R
              If (l-b) < x ≤ l; Matcad use formulae 3 to solve R
              For any other values of x, Matcad use 0 to solve R
              If 0 ≤ x ≤ a; Matcad use formulae 1 to solve Vx
              If a < x < (l-b); Matcad use formulae 2 to solve Vx
              If (l-b) ≤ x ≤ l; Matcad use formulae 3 to solve Vx
              For any other values of x, Matcad use 0 to solve Vx
Sure. Simply replace "Result <-- 1" by "Result <-- <formulae 1>" etc.
