Mathcad 15 M50 Error: The Operation Completed Successfully
  • January 13, 2020
  • 3 replies
  • 3210 views
Mathcad 15 M50 Error: The Operation Completed Successfully.
v15 is needed to open and convert older file formats, but V15 will not run. Windows 10 64bit, users do not have admin rights.
Best answer by ptc-2648087
Created a ticket, no help. One of our techs found making a .bat file and running the Mathcad executable via the following command, works around the issue.
start "" "C:\Program Files (x86)\Mathcad\Mathcad 15\mathcad.exe" && exit
Mathcad Prime versions execute normally.
Open a new case by using "Mathcad Support Center": https://support.ptc.com/support/mathcad_supportCenter.htm
such unexpected answers make one suspect that the computer is invaded by bad software. So I advise you to do a total system restore and install immediately after a good antivirus not free, then install Mathcad 15. There will no longer be problems.
ptc-26480871-VisitorAuthorAnswer
