Mathcad Community Challenge November 2024 - Frustums and Pyramids
  • November 1, 2024
  • 8 replies
  • 10826 views
This month’s challenge is based around pyramids and frustums (a pyramid that’s had its top removed by a plane parallel to the base). Choose any or all of the following and create a Mathcad worksheet:
Moderate Challenge
Calculate the volume and surface area of the frustum in the image below. A Creo 7.0 part model is attached to this challenge for verification.
Note that the original pyramid is a right pentahedron. (A line joining the center of the base and the vertex of the pyramid is at a right angle / perpendicular to the base. See the CAD model and image for additional clarification.) The base and top surface of the frustum are both square.
Optional 1: Create a function that calculates the volume given the 3 dimensions above: edge length of the base, side edge length, and top face edge length.
Optional 2 (for Mathcad Prime 10 users): Use the slider advanced input control to change either the height of the slicing plane or length of the side edge, and recalculate the volume.
Hard Challenge: The Pyramid of Least Volume
“Of all the planes tangent to the ellipsoid
 one of them cuts the pyramid of least possible volume from the first octant x ≥ 0, y ≥ 0, z ≥ 0. Show that the point of tangency of that plane is the centroid of the face ABC.”
The pyramid in this situation has four sides. One of the corners is at the origin (0,0,0). The centroid is this case means the intersection of its medians.
(Source: “The Mathematical Mechanic” by Mark Levi, section 3.5.)
Documentation Challenge
Create a Mathcad worksheet that uses text and image tools to explain the derivation of the formula for the volume of a pyramid.
Find the Mathcad Community Challenge Guidelines here!
"Note that this is a right pentahedron":
I count 6 surface faces, I'd call it a hexahedron....
You are correct. "Right pentahedron" described the original pyramid before the top was cut off to form the frustum. I have edited the original post to reflect that distinction.
I am not sure if "right pentahedron" really describes the object fully.
I would have called it a "straight regular square four-sided pyramid" and I guess we could remove the "regular"  and "four-sided" when we have 'straight' and "square". But then, I am all but an English native speaker ...
BTW, I just looked up the book of Mark Levi and the general non-math proof in 3.6 is a real nice one!
Ok, here's my entry with Prime 10 Express.
Alan
DJNewman
18-Opal
November 13, 2024
PTC Marketer Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
DJNewman
18-Opal
November 21, 2024
It's come to my attention that November is only 30 days long, so...  as we are over two-thirds through November now, time is running out for entries to this challenge! Don't miss the deadlines...!
We'd love to see as many entries as we can. It's very good seeing different perspectives on how to tackle problems.
OK, here are my 2 cents
Only the second part of the challenge, the proof.
Prime 10 was able to handle this almost entirely on its own, only a little help from legacy Mathcad was needed in one place.
Maybe an incentive to improve Primes Symbolics a little further in this direction... 😉
Nice work!
It's also easy enough to get a symbolic solution to:
by hand, without resorting to another CAS program:
Alan
@Werner_E wrote:
... as normally you can't expect that the system falls apart in this convenient manner.
Very true, However, no CAS system is perfect, so I think it is always worth seeing if one can provide a "helping hand" when it struggles!
Alan
ttokoro
Alright, here is my entry.  Please enjoy (if possible;).
I am a structural engineer so I might tend to skip steps than in a more rigorous, academic proof.  Generally, those that review my engineering work are very familiar with the concepts I present, so I usually go for the simplest consistent formatting—I do not want to miss anything.  And I add plots whenever I can so that I can tell if something is not quite right.
I hid much of the grunt work for the plots, you can reveal them easily enough in the Mathcad sheet.
Here are sample screen shots:
DJNewman
18-Opal
December 12, 2024
Your solution blog is published!
https://www.mathcad.com/en/blogs/community-challenge-frustums-pyramids
(....and badges will be distributed... sometime soon.)
