Mathcad Prime 3.0 Plotting
I've used MathCad in the past for simple tasks but never for heavy graph plotting.
I have a MathCad Prime 3.0 sheet that have a set of equations that take inputs at the top of the sheet.
As it runs through each set of the equations it reaches the final equation which provides me with the single answer.
So in very simplistic fashion as shown here I have three known values that two are used in the first equation and the solution from the first is inputed to the final equation to give the answer T.
A=1
B=2
C=5
L=A^2+B^2
T=L*C
Now I want an XY plot graph that shows A on the X axis and T on the Y axis. And then show multiple lines depicted by the changing of B.
So the graph would have lines for each value chosen for B and plot each line with A changing and the output of T.
The sheet is just one set of equations for a single input and a single answer output.
Is there a way to take that and have the inputs varied and plot the outputs as described above.
What steps or functions on MathCad Prime 3.0 would I have to do to make this possible.
Here's an example of a graph I would hope to get. Thanks.
