Motor Toque caclulation using standard formula
- September 13, 2012
- 1 reply
- 3894 views
I'm trying to calculate motor torque using a standard equation that includes a constant that obviously has units associated with it, but are not named.
I've pasted an image of the M' sheet as well as attaching the sheet in XPS format.
The basic motor torque formula uses the constant 33000. Does anyone know off hand what units I would need to give this to make the formula come out corredtly? The output is lbf-ft. I did the unit-less calculation underneath the formula so show what the answer should be.
