Multiplication using
GLeBaTi
8-Gravel
Hi. In my book about mathcad i have a formula (upper image), and i was try write this formula in mathcad (lower image). But result does not match. Maybe i lose some arguments?
the value in brackets when "i" = 1 is 0.  Multiply anything including a large number of products is zero.
set the limits of the product from i=2 to n.
Cheers Terry
20 REPLIES 20
Cheers Terry
-MFra-
(To:GLeBaTi)
The produttoria must start from 2 to get as a result 1/2
Oh. Thanks! Maybe this book hame misspellings 🙂
(To:GLeBaTi)
Obviously it has 😉
In Mathcad or Prime you can also use a shorter (but mathematical somewhat sloppy) notation:
LucMeekes
(To:GLeBaTi)
Makes me wonder: which is your 'book about Mathcad'? (Title, author...)
original book maybe not have misspelling.
I am reading the book in pdf format what have scan errors 🙂
LucMeekes
(To:GLeBaTi)
From 0 to 1/2 or from 2 to 1 is too different to be a 'scan error'....
Again: what's the book?
Page 18 contains correct text and wrong formula.
Martin Hanák
(To:GLeBaTi)
@GLeBaTi wrote:
http://static1.ozone.ru/multimedia/book_file/1009545514.pdf
Formula in PAGE 18(29)
This book: https://www.amazon.com/Vysshaya-matematikana-baze-Matcad-Obschij/dp/5941574703
A few lines above you see that its meant starting with i=2:
LucMeekes
(To:Werner_E)
To get this (appearance of) symbolic output in Mathcad they must have done some work:
either define the value of 2 to a variable the name of which appears to be 1, or
it was a picture cut and paste.
Exactly right!  Involves a key combination not available in Prime:
There should be a way to pull this trick in communication with my bank. Imagine how I then could easily double the deposits, or halve the withdrawals.Smiley Surprised
I don't think that what we see in the pdf is a real screenshot of a Mathcad expression. Rather it was typeset in the printing house and the typesetter made a mistake.
not typesetting!
Yes, I know that a look alike can be done in Mathcad, but I was talking about the pdf of that book. If I look at the typeface used, the size of the product character Pi in relation to the other characters I don't think that we see a screen shot here and guess it was rather typeset (with an error).
BTW, we could also fake that in Prime, too:
ttokoro
(To:Werner_E)
LucMeekes
(To:ttokoro)
That result should be undetermined, rather than 1/2.
(To:LucMeekes)
We are just playing around to reproduce the typo in the russian pdf and other similar nonsense using Mathcad or prime tricks which Valery would like 😉
skunks
(To:ttokoro)
Smiley Happy
