23-Emerald I
June 2, 2017
As written your three constraints don't form a closed space (turn the inequalities into equals and plot:
If you invert the third constraint, the possible set closes, and the problem solves
rbala?ic1-VisitorAuthor
This solution is not good, because the result is incorrect. The right side of inequality representing the production limitations and should not be changed. The real solution is the following figure.
23-Emerald I
June 6, 2017
Ah-hah!
Your original post was missing two constraints:
Without the additional restrictions that the values had to be GE 0,
the problem was unbounded
