Non-linear equations system
  • April 24, 2021
  • 5698 views
Trying to solve a systems of 3 equations with 3 unknowns by means of SOLVE BLOCK and MINERR function. (or find). It doesn't provide any error message but it seems not to calculate any root; it simply provides the three guessed values as the results without running any iteration.
Attach the file please.
Cheers
Terry
Here the file and the solved example from a book.
Thanks a lot!
Thanks a lot for you great help!
Despite the example has taken from a technical manual, you're right that equations have been manually modified...
Unfortunately I've already tried  with these new set of equations (i.e. for stiffened liners) but I get almost the same results; not convengerce or imaginary solutions.
