Optimization Problem
  • August 9, 2020
  • 2 replies
  • 6321 views
Hallo community,
actually i have an optimization problem and want to aks if that is possible in mathcad.
For example if i have 8 input variables what i need to optimize and a few boundarys and a long calculation.
Is that possible within mathcad?
What good other program is there available? I have complicated formulas which are moore easy do write within mathcad because of the good mathematic notation and hard in other software like excel. But mathcad can only calculate on 1 cpu
The other problem is that i even dont know initial parameters for my variables to get a correct result so i need to exclude nonsense range of variables. I think i should be able to use a cpu cluster so i should be able to use more than 1 cpu fopr optimization problems
Thankx Stefan
Hi
Yes.
The free program Scilab can easily work the problem out.
Let the program work the cores not you.
Cheers
Terry
Try at first in Mathcad!
I hope we can help.
I have solved a lot of optimization problem in the field of mechanics.
Some of its is here
2^5 Problems for STEM Education
See please chapters with optimization problems
Study 8. Live kinematic schemes Or Arm of Hella
Study 20. Journey from home to school on the Fermat route Or The second optical property of hyperbola.
Study 21. Optimization of potential energy Or Curves of the second order in statistics
Study 25. Hybrid calculations on the computer Or One more about a cone
Study 26. Funicular Polygon in Static, Kinematics and Dynamics Or Isaac Newton vs Joseph Louis Lagrange
You can free download Mathcad-sheets from this site.
But if your problem is very... you must create own program with own algorithm...
can i run mathcad 15 optimization problems with like 20 cpus in a cluster?
I think optimization problems with like 8 to 10 input variables do need multiple cpus run
Hallo,
thank you for the file. Is it possible to define a certain step width for the variables which have to be changed in order to speed up calculation?
I do not know initial values for the variables in order to fulfill all side conditions. Is this a problem?
Thank you br Stefan
