Plotting in Prime 11 does not work as it works in Mathcad 15
  • January 4, 2026
  • 203 views
I have a Mathcad 15 file where I can plot the absolute value of two functions that have real and imaginary components. When i converted the file to Mathcad Prime 11 it provides error. Because the graphs are at the end of the calculations sheets, i am only providing screen shots for now, to avoid having to attached the complete calculation sheets. But let me know if i need to submit the complete files for review.
thank you in advance,
Rogelio
Best answer by LucMeekes
You had not defined x.
You set the limits for x with unit m. When plotting with units, you MUST define x,
So add, above the plot:
and the plot works.
Hard to tell without seeing the sheet.
Especially it is not seen how x is defined.
If possible it would be best to post the sheet.
Ok, here you have, thanks,
I simplified the two calculation sheets, one in Mathcad with the correct plot and one in Prime with no plot possible.
Thanks in Advance,
Rogelio
LucMeekes23-Emerald IVAnswer
and the plot works.
